Go Back   The RadioReference.com Forums > Site Administration Forums > Wiki Forum
Wiki Forum - Discussions regarding the RadioReference Wiki
Old 01-29-2018, 2:32 PM
Wiki Admin Emeritus
Default Using infoboxes
There seems to be a bit of confusion regarding the use of the Infoboxes when defining TRSs to the wiki. The regular use ones are defined in our guide here...
Templates-List: Infobox-Related - The RadioReference Wiki
See section 2.1.3 for the ones we use on a regular basis. Note that some of them as they broaden in scope, require less and less information to be filled in. From the most to the least;
Infobox TRS
Infobox TRS Multicounty
Infobox TRS Multistate
Infobox TRS Military
Infobox TRS Federal
So, for example, if a public sector TRS covers more than one county, then the Multicounty infobox should be used.
Additional links to the FCC licensing information is fine, but the first 3 infoboxes have links to the FCC data in our database. The last 2 will not, as the FCC doesn't keep this data and is restricted.
TIA to everyone who is attempting to use these structures; it makes having to do catch up a lot easier...Mike
