Dittronics Wiki Entry
AC0RV
Park Hills, MO
Ok Dittronics has an older page which has it as LTR system. But I have found three separate
DMR- XPT (which is program into the #36hps as MOTOTRB system. So do I create three separate systems or one DMR page. Each of the systems use the same TGIDs and UIDs.
Please advise.
Big thanks.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
The 3 that I think you are seeing are in red, and therefore undefined. I think you're seeing them here, right?
Missouri TRS- the RR Wiki
The one Dittronics that is there goes back to a Deprecated database entry, so I will move it and modify the article.
Now to your question - I think you are wanting to document this, but it only shows 2 sites
https://www.radioreference.com/apps/db/?sid=9964
In any case, since there is more than one county, use the Multi-County template to build an article for it, and be sure to include the DMR template to put the proper warning on it. The template and some doc for it can be found here...
https://wiki.radioreference.com/index.php/Template:Infobox_TRS_MultiCounty
If you look at the 'What Links Here' in the Toolbox to the left, about 2/3 of the way down, you will see many examples of how to code the template. It requires less than a single county box because there are templates behind the scenes that take over a few of the required functions
If you need further help, please ask and we'll jump in...Mike
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
In fact, the deprecated entry has a good chunk of what you need...
Dittronics UHF SeMO - the RR Wiki
All you need to do is to copy it, remove the deprecated text call at the top, assign proper categories, then make any of the adjustments in the infobox you need. Remember since this is a DMR system, you must put the DMR warning template on the article. Edit this article to see how its done...
https://wiki.radioreference.com/index.php/Horseshoe_Casino
Then all you need do is edit the Trunked Radio Systems article and put the link for your new article there. You can use one of the Dittronics entries as a model, and drop the other two
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
If you want to see what categories exist for Missouri, simply go to the very bottom of the state article and select one of the 3 links there. They are listed in various ways, but the alpha sort is the easiest to understand...
Missouri - the RR Wiki
