Target 2 way radio frequencies
zsauve
Oak Creek, WI
Does anyone know what frequencies Target uses, specifically the target in Oak Creek? I have the same exact radio model they use (Motorola CLS series) so if you only know the frequencies and codes by the number (Frequency 3, 5, 10 Ect..) Also the radio frequencies listed by others, are they universal wherever a target store is located in the US?
MarcusDude
Milwaukee, Wisconsin
Most Target stores use 4 channel UHF radios with one of the following 2 channel plans:
Channel Plan A (I got conflicting info for channels 3 and 4):
467.75000 D115 Target Ch. 1 Store Ops/Automated Paging
467.77500 D072 Target Ch. 2 Executive
467.92500 D115 or D155? Target Ch. 3 Backroom
467.87500 D244 or 467.90000 D205 Target Ch. 4 Assets Protection/Hardlines
Channel Plan B:
461.03750 D026 Target Ch. 1 Store Ops/Automated Paging
466.28750 D032 Target Ch. 2 Secondary/Backroom
469.48750 D047 Target Ch. 3 Assets Protection/Hardlines
462.91250 D065 Target Ch. 4 Executive
gewecke
Banned
Illinois
Channel Plan B:
Any idea if this channel plan includes stores in illinois?
Thanks!
n9zas
Myles
Houston TX
In addition to the above plans listed, there is one other plan I have seen:
467.5125 D115 Ch.1
467.4875 D072 Ch.2
467.4625 D244 Ch.3
467.1875 D306 Ch.4 Assets Protection
As far as I know, these are pretty much the new UHF plans across the US, of course, I wonder if changes might be made to certain channels to accommodate other local businesses.
zsauve
Oak Creek, WI
We are probably on Radio plan 2. most are probably on 2 Because I've seen Motorola CLS1410 radios in use. In order to use Plan 1, they would have to have a radio that would use custom frequencies like Kenwoods or the Motorola CP200.
I also found out that they used to use MURS frequencies, they probably dropped their use because Wal-Mart threw a temper tantrum and forced Target of of those frequencies because Wal-Mart never has heard of or know what PL/DPL tones are.
N9NRA
Also be aware that these are low power (at least the store here uses low power radios), so you probably won`t hear them to far from the store itself, i loaded the channels in my radios thinking i`d be able to hear `em from my place and i can`t. Couldn`t hear anything till i was practically at the store here in town, here we use plan 1, now that i know this i`ll just load the other freq plans into the scanner and see what i get, thanx for posting this info :). N9NRA
N9NRA
Just curious, but anyone happen to know what the Superior store is on as far as radio plan? Might load the other plans into the scanner and see if i hear the Superior one when i get up there. N9NRA
zsauve
Oak Creek, WI
Wal-Mart uses MURS frequencies
hey do u have the wallmatr freq for the wal mart on capitol dr in Wisconsin by chance thx
Most Wal-Marts i have come in contact use MURS frequencies .The most common MURS frequencies wal mart uses are 154.5700 & 154.6000. If you see employees with Motorola XTN or RDX radios, there is a good chance they are VHF & they are using MURS. Also most wal marts don't use PL/DPL codes, they are on CSQ.
jaspence
Michigan
Wal-Mart MURS
In several stores I have been in they use a CTCSS of 67, probably because it is the easiest to set in a hurry.
wtp
Port Charlotte FL
but
they can transmit with the tone but if theat function is not used or receive it doesn't matter.
i have seen multiple pl's used in one store as they talk back and forth.
WQJQ863
Can't Follow Simple Instructions
Banned
My local walmart uses 154.570 dpl of 754 for tx rx and the rdx radios work ok I had programmed them for walmart when they opened their new store in waukesha!!!!!
a1vtmv48
Corner Brook Newfoundland
TARGET CANADA CO. Atlantic Provinces
Tx Rx Location Licensee Details
458.2000 458.2000 CORNER BROOK, Newfoundland TARGET CANADA CO. PROPERTY ACCOUNTING 66105606001
458.3750 458.3750 CORNER BROOK, Newfoundland TARGET CANADA CO. PROPERTY ACCOUNTING 66105606003
458.7250 458.7250 CORNER BROOK, Newfoundland TARGET CANADA CO. PROPERTY ACCOUNTING 66105606004
458.2250 458.2250 CORNER BROOK, Newfoundland TARGET CANADA CO. PROPERTY ACCOUNTING 66105606002
458.2000 458.2000 ST JOHNS, Newfoundland TARGET CANADA CO. PROPERTY ACCOUNTING 66105607001
458.2250 458.2250 ST JOHNS, Newfoundland TARGET CANADA CO. PROPERTY ACCOUNTING 66105607002
458.3750 458.3750 ST JOHNS, Newfoundland TARGET CANADA CO. PROPERTY ACCOUNTING 66105607003
458.7250 458.7250 ST JOHNS, Newfoundland TARGET CANADA CO. PROPERTY ACCOUNTING 66105607004
458.6625 458.6625 BEDFORD, NS 1658 BEDFORD HWY, TARGET CANADA CO. PROPERTY ACCOUNTING 63036771001
458.6625 458.6625 194 CHAIN LAKE DRIVE, HALIFAX, NS TARGET CANADA CO. PROPERTY ACCOUNTING 63036773001
458.6625 458.6625 21 MICMAC BLVD, DARTMOUTH, NS TARGET CANADA CO. PROPERTY ACCOUNTING 63036774001
458.6625 458.6625 CHARLOTTETOWN, PEI - T3637 TARGET CANADA CO. PROPERTY ACCOUNTING 65036080001
460.7750 460.7750 CHARLOTTETOWN, PEI - T3637 TARGET CANADA CO. PROPERTY ACCOUNTING 65036080003
465.7750 465.7750 CHARLOTTETOWN, PEI - T3637 TARGET CANADA CO. PROPERTY ACCOUNTING 65036080004
469.2625 469.2625 CHARLOTTETOWN, PEI - T3637 TARGET CANADA CO. PROPERTY ACCOUNTING 65036080002
458.6625 458.6625 SAINT JOHN, NB - T3655 TARGET CANADA CO. PROPERTY ACCOUNTING 65036081001
460.7750 460.7750 SAINT JOHN, NB - T3655 TARGET CANADA CO. PROPERTY ACCOUNTING 65036081003
465.7750 465.7750 SAINT JOHN, NB - T3655 TARGET CANADA CO. PROPERTY ACCOUNTING 65036081004
469.2625 469.2625 SAINT JOHN, NB - T3655 TARGET CANADA CO. PROPERTY ACCOUNTING 65036081002
458.6625 458.6625 MONCTON, NB - T3566 TARGET CANADA CO. PROPERTY ACCOUNTING 65036082001
460.7750 460.7750 MONCTON, NB - T3566 TARGET CANADA CO. PROPERTY ACCOUNTING 65036082003
465.7750 465.7750 MONCTON, NB - T3566 TARGET CANADA CO. PROPERTY ACCOUNTING 65036082004
469.2625 469.2625 MONCTON, NB - T3566 TARGET CANADA CO. PROPERTY ACCOUNTING 65036082002
460.7750 460.7750 FREDERICTON, NB - T3550 TARGET CANADA CO. PROPERTY ACCOUNTING 65036083003
458.6625 458.6625 FREDERICTON, NB - T3550 TARGET CANADA CO. PROPERTY ACCOUNTING 65036083001
465.7750 465.7750 FREDERICTON, NB - T3550 TARGET CANADA CO. PROPERTY ACCOUNTING 65036083004
469.2625 469.2625 FREDERICTON, NB - T3550 TARGET CANADA CO. PROPERTY ACCOUNTING 65036083002
KISSIMMEE, FL
Target Radio Channels
Channel 1: 467.750000 DTCS Code 115
Channel 2: 467.775000 DTCS Code 072
Channel 3: 467.925000 DTCS Code 155
Channel 4: 467.900000 DTCS Code 205
I use these frequencies on my radio for work at target. From what I'm told all the targets use the same frequencies.
