Go Back   The RadioReference.com Forums > Service Specific Monitoring > Aircraft Monitoring Forum > Aircraft Data Decoding
Aircraft Data Decoding - A forum to discuss decoding the various data transmissions such as ACARS, Mode-S, ADS-B, etc.
  #41 (permalink)
Old 02-29-2016, 8:49 AM
BM82557's Avatar
Default Helo symbol??
I was wondering if there is a way the db admins can setup a helo symbol for helos instead of the normal plane symbol that appears to be in use now? Click on the thumbnail below for a larger image -
  #42 (permalink)
Old 02-29-2016, 3:43 PM
freqhopping's Avatar
I've been taking care of that as I see them active. The database auto-populates from PlaneBase and the ICAO type field gets populated with the full model name rather than the ICAO type. I've been editing the records of all interesting A/C so the proper ICAO type is there and thus the proper icon displays.
Spinning & Grinning
Alinco DJ-X11 - BC890XLT - 436HP - BCD396XT - BCD996T- PSR-800 - Pro-106 - MilTenna LP in the attic.
  #43 (permalink)
Old 02-29-2016, 4:56 PM
frazpo's Avatar
Good info. I was just pondering this issue a while ago.
BCD436 - TRX1 - SDR - 890XLT - BCT15
  #44 (permalink)
Old 03-07-2016, 8:43 PM
BM82557's Avatar
Default 249249 GOTOFMS
Here's an odd one on ADSBexchange from 17:56 local this evening. The GOTOFMS I've seen in the past have been E-6B's. I checked Scramble and 167899 is supposed to be an MH-60S BUT helos are not at 33000' making 441 mph.
Click on the thumbnail for a larger screenshot -
  #45 (permalink)
Old 03-08-2016, 4:13 AM
Yeah, somebody changed my modification of the database where I had this being for E-6B 164404, which it is most of the time. Looking at the reports for past flights it's pretty clear which aircraft is using it and getting logged the most.
Spinning & Grinning
  #46 (permalink)
Old 04-01-2016, 10:29 AM
Markb's Avatar
This morning I am getting an "error establishing a database connection". Is everyone else seeing the same thing?
  #47 (permalink)
Old 04-01-2016, 10:33 AM
Yeah it seems to be offline for some reason.
  #48 (permalink)
Old 04-01-2016, 10:41 AM
Markb's Avatar
Okay. I just set up to share yesterday and noticed that after a time the display page reverts to the home page. Whenever I went back to the display, aircraft would not show (as in a blank map). I had to clear my browser cache for it to work properly again. I am using FireFox.
Is this normal behavior or possibly related to the outage?
Sent from my SM-G920V using Tapatalk
  #49 (permalink)
Old 04-01-2016, 10:42 AM
BM82557's Avatar
It was like that for a while yesterday, I think it was overloaded by users watching the combat air patrol over Washington, DC.
  #50 (permalink)
Old 04-01-2016, 10:47 AM
Markb's Avatar
OK, thanks!
  #51 (permalink)
Old 04-01-2016, 12:23 PM
BM82557's Avatar
Outage report - Recent Outages.. ADS-B Exchange
  #52 (permalink)
Old 04-01-2016, 3:03 PM
Markb's Avatar
Seems to be back up.
I am still having this pesky issue with Firefox not loading aircraft onto the page after a while. Microsoft Edge seems to display everything without any problem.
  #53 (permalink)
Old 04-01-2016, 3:38 PM
My Firefox isn't loading it now, but Chrome seems to be working fine.
Or not, tried to open another tab in Chrome but it timed out. The other tab is still working.
Spinning & Grinning
  #54 (permalink)
Old 04-02-2016, 9:23 AM
BM82557's Avatar
Site is down again -
Error establishing a database connection
  #55 (permalink)
Old 04-03-2016, 2:40 PM
BM82557's Avatar
Default What are these stations?
I've noticed what appear to be ground stations that show up under the military filter on AdsbExchange. The two in Australia always display as ground and the one in Austria is always 6800' (Google shows the co-ordinates as being on a mountain). The one is Slovenia has just appeared in the last several days. The squawks are always the same, 7777. 7712 and 7722. Any ideas as to what they are?
  #56 (permalink)
Old 04-03-2016, 3:39 PM
kma371's Avatar
Global DB Admin
Possibly radar stations.
  #57 (permalink)
Old 07-01-2016, 2:06 PM
So I just started using ADS-B Exchange (which is amazing, BTW!), and I'm wondering about the callsign field. It appears many aircraft have the Tail Number in the callsign field, and others leave it blank. Lately I've noticed when I listen to certain aircraft on VHF airband freqs, the *actual* call sign is different from what's listed in the ADS-B broadcasts. Is that callsign field basically meaningless for most aircraft at this point? Do some aircraft use their "actual" callsign for this field?
"Huhh?? Of COURSE I don't have enough radios, shouldn't that be obvious??! My vehicle has lots of space to put more radios, I certainly do NOT have enough!"
  #58 (permalink)
Old 07-01-2016, 2:09 PM
frazpo's Avatar
Default adsb exchange forum
Hop on over to the forum on adsbexchange site.
also join the adsb dump1090 FB group. https://www.facebook.com/groups/476880835847288/
Myself and others, more so, edit the database. They can answer your questions that are relevant to adsbexchange.
  #59 (permalink)
Old 07-01-2016, 10:03 PM
Markb's Avatar
The callsign field is entered by the flight crew. In most cases, there doesn't seem to be a hard and fast rule about updating/entering correct callsigns (the classic E-6B "GOTO FMS" is a classic example). There was a thread here a few years ago about some of the funny, if not inappropriate callsigns seen on ADSB.
  #60 (permalink)
Old 07-09-2016, 10:28 PM
I am looking for some help,i want to set up a feed for Adsbexchange from my local area so many aircraft,low level that are currently not showing.I'm having a problem with software,i already have a dongle and adsb antenna for 1090,i may have to add a filter.Either step by step instructions or someone to come and help me set it up i just want to set it up and try it.I have to buy things a little at the time because of money.I do not drive due to a head injury,Thanks!
Tags
ads-b, adsbexchange.com, mode-s, virtualradarserver, vrs
