Go Back   The RadioReference.com Forums > Service Specific Monitoring > Aircraft Monitoring Forum
Aircraft Monitoring Forum - This is the place to discuss monitoring civilian aircraft communications.
Old 03-09-2005, 8:48 AM
EMD91123's Avatar
Default ARTCC Sector Boundary Charts w/frequencies
Does anyone have any ARTCC sector boundary charts w/their frequencies ? Looking for particularly Minneapolis,Indianapolis,Toronto,and Montreal ACC's.I live down here in the NY area will gladly trade info of any type in return for said items.Both huigh and low altitudes are seeked here.Thanks
Mike.
Old 03-09-2005, 10:14 AM
http://microvoltradio.com/ARTCC/ARTCC.htm
http://www.milaircomms.com/artcc_frequencies.html
Tom
Old 03-09-2005, 10:20 AM
EMD91123's Avatar
Actually have those bookmarked however they are not too much up to date.There are frequencies that I hear from LIVEATC.com that arent listed in those webpages.Again Thanks charts would be greatly appreciated w/their frequencies
Old 03-09-2005, 10:48 AM
check out milaircomms.com. I thnk you will find what you're looking for.
http://milaircomms.com/artcc_frequencies.html
Jon
Old 03-09-2005, 11:01 AM
IdleMonitor's Avatar
Default Re: ARTCC Sector Boundary Charts w/frequencies
If you're looking for Canadian stuff, you can check out http://www.canairradio.com/
Mike.
Old 03-10-2005, 5:30 AM
edN's Avatar
edN edN is offline
There are frequencies that I hear that arent listed in those webpages.
There are several newly assigned ARTCC freqs in my area. Check your local notams.
Old 03-10-2005, 8:21 AM
druhe's Avatar
Default This brings up a question
This brings up a question, where do you find "local" notams ? I've been looking and can find them for areas other than where I live. We just had a frequency change (luckily I caught it off the air) the controller referred several arriving aircraft to the notam. By the way I'm in Johnstown, Pa.
--Dan-- KE3UC
Old 03-10-2005, 9:22 AM
DaveNF2G's Avatar
Milaircom doesn't note when they last updated. All of the copyright notices are 2001, and there are listings that are outdated for those ARTCCs that I can monitor.
David T. Stark
NF2G WQMY980 KYR7128
Old 03-10-2005, 10:13 AM
Then download the IFR Supplement. I posted the link here:
http://www.radioreference.com/module...ic&t=21556
I figured the other websites had up to date info from the FAA or something.
I guess not.
Tom
Old 03-10-2005, 10:14 AM
I found 2 links for NOTAMS
https://www.notams.jcs.mil/
https://pilotweb.nas.faa.gov/distribution/atcscc.html
Tom
Old 03-10-2005, 12:29 PM
EMD91123's Avatar
actually got all those websites on the computor thanks guy's again if anyone has charts of artcc and acc sector boundaries w/their latest frequencies i will be more than happy and more than happpy to share info also if any of you guys need stuff from the ny area
Old 03-10-2005, 12:39 PM
This site will show the boundaries, but not freqs
http://tfr.faa.gov/tfr/tfrmap.jsp
For the freqs, download the IFR suppl from here:
https://164.214.2.62/products/digitalaero/index.cfm
Rod
Atlanta
Old 03-10-2005, 3:39 PM
kiwirat's Avatar
Default ARTCC Frequencies
This webapge has all you would ever need, it hasn't failed me yet.
Old 03-10-2005, 6:55 PM
pocho's Avatar
Here is Minneapolis Center.
http://www.freqofnature.com/aviation/zmp/index.html
8)
Old 03-11-2005, 2:05 PM
cipher66's Avatar
ARTCC DB Manager
Here's Boston ARTCC:
http://www.bostonartcc.net/Boston-Ce...w-Altitude.jpg
-and-
http://www.bostonartcc.net/Boston-Ce...h-Altitude.jpg
:P
Paul
RadioReference.com ARTCC Database Admin
Old 03-11-2005, 11:41 PM
Spleen's Avatar
And you can always pop into your local airport and pick up an Airport/Facilities Directory....they cost four or five bucks....they're "officially" accurate for two months but are a good starting point for ARTCC and a boatload of other frequencies...
http://www.naco.faa.gov/index.asp?xm...y/af_directory
Old 03-24-2005, 9:31 PM
oliattrinity's Avatar
Default AirFreqs
Found decent info on www.airnav.com
Old 07-25-2005, 11:33 PM
davidp124's Avatar
If you subscribe to Flight Explorer you will be able to access a mapping feature that not only shows ARTCC boundaries but low, high, and ultra-high sectors. This is a great companion for the scanners. Mapping also depicts locations of ATC Radars.
Old 11-14-2013, 9:48 AM
I have been using the milaircomm site a good bit since getting back into mil air listening. Their ARTCC and airport frequencies appear to have been updated August of 2013. They now list the last update date for each frequency here Military Comms ARTCC Center Frequencies and Sector Maps
Not long ago I noticed a new page added to their site. It is a map of the ARTCC radar sites, it neat to zoom in on the map and see a google maps view of the actual radar Military Comms ARTCC Center Radar Site Map
Old 11-14-2013, 9:50 AM
That map appears to be lacking a lot of radar sites.
Tom
