I have received delivery of a 125AT scanner I purchased, along with the SRH-320A antenna
After unboxing it, reading the manual and using it, I am highly disappointed.
I scanned from 108 to 512 and picked up only 3 or 4 signals during the daytime.
Mind you, I live in a suburban area, near a major metropolitan area -- definitely not the middle of nowhere -- so this is surprising.
At first I thought it had something to do with the squelch or the settings, but, that wasn't the case.
Unfortunately, as far as reception, this scanner's front end leaves much to be desired. I have an older Uniden scanner and compared to that, the 125AT is practically deaf.
