scanmanmi
Do they do this in the US like the UK?
https://www.youtube.com/watch?v=obt7O4INRD4
I've worked on airline ground crews and in the tower and I have never heard of FM links from AM air used in the US. Ground vehicles usually have AM radios if they need them. We had FM UHF ground radios and I never heard air AM over them. Aircraft can communicate on company radios in the FM bands though, usually to dispatch.or maintenance.
I don't know of a relay to airband, but Southwest talks to aircraft on the ground on UHF at KALB.
The short answer is no. While there are still a handful of microwave links in existence (mainly for backup purposes, on frequencies your scanner is not going to pick up anyway), it is mainly telco lines that are in use, via AT&T or such.
Can you elaborate on that? UHF to/from the aircraft? I think not. I've worked for Southwest for 21 years as an A&P Mechanic, our aircraft are not equipped with UHF radio comm. Only our ramp agents and ops agents use business radios like DMR Cap plus and UHF motorola.
Wrong thread ???
Uhhhhh....no.
I noted that there are no "ground repeaters" for pilot/ATC comms. Any link to remote radio sites or such are done via Telco and microwave links. There are no UHF links that you can listen to on the Baofeng radios, and hear airband communications.
No one was talking about Microwave Links.
And Yes there are FM Repeaters and Simplex patching to the Air [AM] bands at some airports.
All depends [as my original example confirmed] on the Operation
Having said that the only other instance of repeating the VHF I'm aware of at McCarran Airport there's a parking/watching lot accross the runway from the terminal that has a very local FM radio repeat. I forget the freq but it's for any car to sit and watch planes land and hear tower comms on their FM radio.
...and in some cases HF but to my knowledge not in use because SWA is not flying ETOPS until next year.
I am talking about microwave links. That's how ATC communicates with the remote transmitter/receivers. That and telco lines. They do NOT use UHF links (especially FM) that can be picked up on the Baofeng radios. That's what the OP was asking, correct?
Your example has absolutely NOTHING to do with ATC Comms. as the video in the original post is showing. Did you actually watch the video? Nobody is talking about UNICOM (which is normally run by the FBOs). I'm sure the FBO is running a UNICOM link to UHF so they can use their UHF business radios to monitor the UNICOM operations, or even talk on the UNICOM frequency from their business radios.
The UK video that was posted originally is referring to ATC. Note, you can actually hear the tower controller talking to the pilots. That does not happen in the US, as the Southwest mechanic and now a FAA Operations Supervisor is telling you. UNICOM is a completely different animal, as are the OPS frequencies for the airlines, i.e. to the Ramp "Controllers". You are absolutely 100% NOT going to hear the Tower, TRACON, or ARTCC on some sort of UHF link, unless some 3rd party is operating the repeater/patch. Do not expect to go to any old airport and hear some sort of magic FAA link on your Baofeng radio, because it isn't going to happen.
Codan makes a crossband repeater that will take UHF FM and retransmit to VHF AM and vice versa. This thread had NOTHING to do with linking to remote sites BTW.
Ok, you are hearing the Ramp Radios from Operations. Pilot to Ops can be heard on 131.8 VHF
Not very often. Those of us who are actually in range of KALB know that some of the VHF channels are obsolete.
The aircraft and the ramp agent can both be heard on the UHF channel I listed.
I wish people who are not sitting in my station or my car at the airport would stop telling me that what I am monitoring is not happening. I have been in this game for quite some time.
[EDIT: In future I will collect tail numbers.]
