Hi all,
Last weekend I built two different airband antennas (tuned to 127MHz): a 3-element yagi and a 1/4 ground plane antennas and tested them separately.
They worked very well at low heights above roof (to a maximum of around 1.5m) but as I increased the height to 5m above the roof my scanner picked up some noise and some local FM stations (at least sounded like that, I can almost understand what was being said). The same phenomena occurred for both antennas with no noticeable difference between them in that aspect. I used (for both) the same coax cable: RG213.
I used a 6m PVC pipe (filled with wood for increased rigidity) and the antennas were attached via zip ties to that PVC mast.
Even so I still heard some distant comms but the thing is that the noise floor increased from no bar to around 3/4 of the maximum signal meter displays bars.
I also noticed that below 50MHz and above 250MHz the signal meter display indicated no bars, so no noise there.
Any idea of why this behavior and how to solve this noise/interference issue?
Thank you
Thank you
