Shelby County Project 25 TRS
Thunderbolt
Global Database Administrator
Moderator
Ann Arbor, Michigan
Shelby County is licensed for the following frequencies, as part of their new Project 25 TRS that should be nearing completion. This system has numerous sites across the county. If anyone can give a listen, and let us know if you hear any activity, it would be most appreciated. Thank you! :)
151.0325
152.9000
154.7850
154.9050
155.0325
155.0550
155.0925
155.0775
155.1150
155.1975
155.4150
155.5425
155.5725
155.6250
155.6475
155.6925
155.7225
155.7450
155.8275
155.8350
155.8575
155.9325
155.9475
156.1875
158.7675
159.6600
160.0500
160.1100
160.1250
73's
Ron
medic9351301
Banned
ron
i got a friend that works for the sheriff's office as of today they are still using conventional vhf for all agencies
puzzleriddle
bham, Bama
Shelby county
AS crazy as this sounds I am monitoring 856.4875 - CC ( with Unitrunker) & have been for a few weeks SITE ID 4D3E . has been intermittent & week until today the line on my PSR500 below the frequency is flashing SHELBY COUNTY & has been for past 30 mins or longer for teh Site name.. hmm what's going on? I will try & post screenshots later
Thunderbolt
Moderator
Ann Arbor, Michigan
The frequency of 856.4875 MHz, is licensed to Vestavia Hills, in nearby Jefferson County. The FCC callsign is WPKH239. However, as to why your radio is flashing "Shelby County" is beyond me!?
73's
Ron
puzzleriddle
bham, Bama
al so Vetavia still on Bham TRS
1175 15120 Grp VESTAVIA FD DISP --- ----5----------------- 94
1176 15152 Grp VESTAVIA FD TAC --- ----5----------------- 0
1177 15056 Grp VESTAVIA PD DSP --- ----5----------------- 392
1179 15088 Grp VESTAVIA PD TAC --- ----5----------------- 1
ke4yzn
Shelby County SO New Trunking System
Shelby Co SO has moved to a new trunking system. Anyone have any info on it yet?
puzzleriddle
bham, Bama
I have heard nothing from my location but still hearing traffic on here 0658 SHELBY CO SO-1 154.785000 FM CTCSS 123.0
ke4yzn
Thanks for the info. I thought they switched already. Thanks
morganAL
Somerville, AL
I know some of the people from the Harris shop that is installing it and they told me that it is in the process of being installed now.
Avery93
AL
Heard a P25 control channel on 160.050 this morning. The System ID and NAC was 296.
The other frequencies are available on the license if anyone in the area wants to monitor them. I would only monitor the frequencies with the "FB8" station class code, as the others are the mobile input frequencies. It would be great if someone could run Pro96Com on the system and post the log files.
puzzleriddle
bham, Bama
and type is moto uhf/vhf??. am trying to get it loaded now & start up pro96.com if I can get a CC from Bham south highlands area. also these are te frqs I pulled from that link check & make sure I have am all
155.69250000
159.66000000
152.9000000
160.05000000
154.78500000
155.94750000
155.19000000
155.41500000
160.11000000
155.54250000
thanks!!
Avery93
AL
155.69250000
159.66000000
152.9000000
160.05000000
154.78500000
155.94750000
155.19000000
155.41500000
160.11000000
155.54250000
thanks!!
It is a P25 system, not Motorola.
That looks like all of the repeater output/control channel frequencies.
Avery93
AL
P25 auto or P25 manual?? that the 2 choices on my PSR500 & Pro197
P25 Auto should work fine. If it doesn't, you will have to run Pro96Com and find out the correct frequency/channel tables, and then enter them in a P25 Manual system.
puzzleriddle
bham, Bama
thanks will double check my settings & start running unitrunker & Pro6.com .. hope to hav something to show for sooon ( If I can pick up CC from here) from here
Thanks again
