herm0016 said:
i would love to know what kind of current the maha mh-a301 amp for the 2m band draws. i am looking at making a powersupply for it to use in my home, 120vac to 12vdc, going to use an old computer power supply or a power brick, not sure what kind of watts/amps that this needs. thanks!
Assume 80% efficiency, the add a 50% safety factor.
10 Watts out needs 12.5 watts in plus 6.25 safety, so you need 18.75 Watts, which is 1.78 Amps figured at 10.5 volts (using the lowest typical voltage from a 12 v system for additional safety)
I am guessing at the 10 watts out, but that should be an easy number to find.
Of measure the thing. (Don't forget to put in margin for safety and transients.)
Also, computer power supplies do not like odd loads like RF amps. Might work, might not.
