Go Back   The RadioReference.com Forums > Scanners, Receivers and Related Equipment Forums > All Other Scanner Manufacturers
All Other Scanner Manufacturers - The forum to discuss all other scanner manufacturers not listed above.
  #161 (permalink)
Old 01-29-2016, 8:28 AM
New FW 5.8 and SW 5.8 released.
http://hrw.3dn.ru/load/0-0-0-22-20
DMR reception improved. Con+ and Cap+ systems audio channels decodes well.
Tier 3 voice on Control Channel decodes well.
And many other...VU meter, Packet Loss Counter e.t.c.
  #162 (permalink)
Old 01-31-2016, 9:46 PM
KC1UA's Avatar
Scan New England Guru
I've noticed a DISTINCT improvement in DMR reception with my UHF model after this update. Thanks for your efforts.
Scott - Scan New England Webmaster
http://www.scan-ne.net
Formerly known as "scancapecod" in this neck of the woods...
Radio Reference MA, RI, & CT Database Admin
  #163 (permalink)
Old 01-31-2016, 9:52 PM
Boatanchor's Avatar
Fantastic - Thanks
What can go wrong, will inevitably go wrong!
  #164 (permalink)
Old 01-31-2016, 10:41 PM
Thanks! Today new SW will be released. And Moto BP comming soon.
  #165 (permalink)
Old 02-01-2016, 4:55 AM
Boatanchor's Avatar
Moto BP?
Whats that?
  #166 (permalink)
Old 02-01-2016, 5:33 AM
Motorola Basic Privacy in DMR.
  #167 (permalink)
Old 02-01-2016, 9:11 AM
dcr_inc's Avatar
Any idea if a 700-800 Mhz version will be produced?
Unications G5 Phase II (2), HP 1, WS1080 (2), PSR600, PSR500, PRO106, Commercial FCC license, Ham General, FAA Private Pilot, Business Owner, APCO Certified Tech.
  #168 (permalink)
Old 02-01-2016, 4:08 PM
RayAir's Avatar
Nice work.
Could you possibly give some details of how MotoTRBO BP works besides using a 16 bit key fed to an LFSR?
Was always
KXKYC JBSOB XBMZE LCVHV WCW
  #169 (permalink)
Old 02-01-2016, 10:41 PM
MotoBP detects automaticly without user interactions.
  #170 (permalink)
Old 02-03-2016, 11:12 PM
RU3ANQ
Just got your email, so you are saying it will work for DMR Motorola Connect Plus (TRBO) system? Right now I have to run dsd plus and 2 sdr dongles one for the control channel and one for voice channels.
But now this will work is what your saying?
  #171 (permalink)
Old 02-04-2016, 7:01 AM
ADCR25 will decode Cap+ and Con+ voice channels only. Not trunked operation.
For the current FW and SW versions (5.9) APCO25 Phase 1 trunking supported only.
FW 5.9 and SW 5.9 released.
  #172 (permalink)
Old 02-06-2016, 9:57 PM
what is the cost of UHF one and what all systems does it support
  #173 (permalink)
Old 02-07-2016, 2:25 AM
FW 5.9 supports:
DMR systems including MotoTRBO (conv only).
APCO25 phase 1 systems (Conv and Trunking)
NXDN (IDAS/NEXEDGE) Conv.
Yaesu C4FM System Fusion. Digital modes.
  #174 (permalink)
Old 02-07-2016, 9:45 AM
FW 5.9 supports:
Does it do both 6.25 and 12.5 on NXDN and does it come with the latest FW and SW already installed, What is the cost for 1.
  #175 (permalink)
Old 02-07-2016, 11:28 AM
buddrousa's Avatar
The information you ask is posted on the website and here if you will read this thread NXDN 9600 and NXDN 4800 are 6.25 and 12.5. Here is the website go look it is in Russian you will have to translate the site and order this by Email. The one thing is this is a band specific receiver only you need 150 meg order VHF you need 460 order UHF you need 800 order the 800 receiver. BE WARNED THEY DO NOT WORK IN THE RAILROAD BAND 160 to 164 is skipped due to the cpu he is using.
ADCR25_PRO2. APCO25/ DMR/NXDN(IDAS/NEXEDGE)/YAESU FUSION RECEIVER. Unit price $179.95. Free shipping WORLDWIDE! - 6
Support your local FIRE & EMS. PRO197-18-107-668:PSR-410 X2: BC8500XLT 785d BCD436HP BCD536HPx3 BCT346 BCD996P2 x3 BCT15x2 BCT15X2 TRX-1 TRX-2 EFJ51SL MTX8250 Tk280 TK2180 MD380x4 NX5300 NX5200 Buddy
  #176 (permalink)
Old 02-07-2016, 11:41 AM
These receivers aren't cheap. Sounds like not a bad deal though. Personally I think I'll stick with my SDR Dongle and DSD+
  #177 (permalink)
Old 02-08-2016, 4:30 AM
Yes, it support both 6.25 and 12.5kHz NXDN with the real BW filtering. IF BW 5kHz for 6.25 and 10kHz for 12.5.
Yes it comes with latest firmware and software. Firmware can be upgraded easily via UPGRADE function for free of charge.
  #178 (permalink)
Old 02-08-2016, 4:36 AM
SDR dongle + DSD+ good idea but its RF parameters are not so good as usually needed.
ADCR25 frontend has far better RF parameters.
Also note that ADCR25 can work in fully stand alone mode. It can do P25 trunk tracking, memory scanning and simple voice decoding without a PC at all. Simple power it up.
Also ADCR25 can do search for DMR, NXDN, Yaesu C4FM and P25 channels with logging.
  #179 (permalink)
Old 02-08-2016, 8:27 AM
Will it do all DMR, NXDN, and P25 in the stand alone mode also or are you limited to one or the other at a time. What i'm asking will it scan all different digital systems at once or are you limited to just one without changing it to another digital system by PC.
  #180 (permalink)
Old 02-08-2016, 10:03 AM
It can decode only one DV standard at a time.
It can scan memory in stand alone mode. Each memory defines frequeency and air interface.
Yes, if you want to change AIR INTERFACE you need a computer with control software.
