Mobile Antenna Suggestion
GrumpyGuard
NEWBERG
I am currently using a Comet Tri-band antenna (2 meter, 1.25 meter and 70 cm). My radio is a Yaesu FT 7800. This antenna is far to big for my car and I was wondering what suggestions would be for a good dual band antenna with NMO mount. The current NMO is attached using a lip mount on the trunk. I know this is not the best way to install, but I am under orders that I can install anything I want as long as I don't drill any holes.
kayn1n32008
ØÆSØ
Sector 001
Larsen NMO 2/70. And if it is too tall go with a Vhf 1/4 wave, as it will resonate in the 70cm band as well
w2xq
Mentor
Burlington County, NJ
On my SUV I use a dual-band Comet B-6 on a hatchback lip mount. No holes. The antenna clears my garage door and parking garages in Philadelphia without any problem. HTH.
Skypilot007
Medford, NJ
I just put a comet SBB-2 on my car. It seems to work well but haven't had much of a chance to try it out yet. On the SWR meter it is very broad banded on UHF with good SWR below 1.5:1 all the way up to 470MHz.
timkilbride
Linn Co Iowa
I did that for several years, worked well.
Tim K.
W2NJS
Washington DC
Look at the Diamond NR72BMO, which is 13.8 inches and covers UHF and VHF. I run two of them on my relatively tall Subaru 2011 Outback. Catalog claims to be a VHF quarter wave and UHF half wave with 2.15 dbi gain on both bands. I don't think there are any dualbanders shorter than this one.
SCPD
QRT
Virginia
Comet SS680 SB. Comes in 2 flavors... NMO and PL29. I've been getting good results wit it.
zz0468
QRT
Banned
I've tried a couple of Larsen dual band antennas, and was not impressed. I had better UHF coverage inside the car with an HT. I was so disgusted with the performance, I lopped the top 6" of the whip and ended up making a 1/4 wave spike out of it. It worked MUCH better.
The 2 meter antenna operating on a 3rd harmonic works ok, but caveat emptor... operated in that configuration, there are several radiation lobes well above the horizon.
GrumpyGuard
NEWBERG
Everyone thank you for the suggestions. I will look into these suggestions and see which one will work best for my setup.
