Arrow Antenna Fox Hunt Loop for HF?
So Far Away....
Spring is here and ive got some scratch for some new antenna's..
Ive been looking for an HF Receive antennas,Portable that dont dent the wallet too much.
Im generally in the city,but travel also,thinking the loop will help with noise to a degree.
specs tell it will cover about 1mhz to 600mhz /1ghz
http://www.arrowantennas.com/main/fhl.html
Opinions?thoughts?
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Foxhunting by hams is generally done, for practice, on 2m/220 or 450 (hence the move to the amateur section), but this could be used to find sources of RFI in the VHF/UHF spectrum.
Antennas this small would be highly inefficient on HF or below, regardless of what the specs say, without some sort of matching or amplification
