The gap "Challanger" vertical I think is great for smaller spaces.
It covers for 2M to 80 M (130 mHz of 80 meters or the 75 meter phone band). It only needs 4 counterpoise radials, 25' each from the base, and they don't have to be streight out at a 90 degree angle from each other to work.
The antenna is a vertical dipole and has got excellent reviews from eHAM.
I just put one up, it required very little space. I have yet to use it because I have my General test is a few weeks, just have my Tech now.
It would be worth looking at, the footprint is small, the antenna is only a foot wide at it's widest point and about 32' tall. The 4 radials are for the 40 meter band only, and I've read where many have had to use shorter one's to be in the center of the phone band on 40 meters, but that I will have to find out when I tune the antenna.
The cost is also very reasonable compared to many others and no need to put down fourty or more 40' to 60' long radials either as most verticals must have to work correctly. (they may not all be 60', but many longer and shorter radials are required for most verticals)
The antenna comes with a pole to put in the ground and the bottom of the antenna sits right at the ground, no need to put it up on a pole of any height above the ground. With a little cement around the pole, they say the antenna is good for 60 MPH winds. I used 4 guy ropes (3/32 Nylon) from just above the middle, they take very little room as we sometimes get some decent winds here, so even the guy rope takes very little room. It just may be the ideal vertical for you. The antenna and the reviews impressed me as well as the fact that it does not have any traps that eat up the signal.
I have no interest in Gap, I'm going off of about 5 pages of reviews on eHam and 95% of the were very good reviews.
My Best, John
