I currently have two hamsticks, one for 20 meters and the other is for 15 or 17 meters (I don't remember and the label is long gone, so I'll have to check it later). I've read that using two hamsticks with a dipole adapter can be quite effective for portable operations. I'm curious if anyone could offer advice on how it would work to use these two hamsticks that are cut for different bands as a dipole through a tuner such as a Z-817. Obviously most dipoles should be the same wavelength on each half, but would it be worth it for me to try this without buying yet another hamstick? If I chose the particular antenna with the correct bandwidth for as the primary half of the dipole, would the antenna tuner correct the "counterpoise" half? This could give me a decent operation on two separate bands if it would work...
