I had a uhf/vhf antenna on a pole 5 ft above a similar light, it did have very mild noise from it I just flipped the breaker and turned it off when I operated.
Pole is mine. Will mount on the backside of pole away from the conduit for the light and extend above the top of the pole as far as possible. 2m 70cm Fong style antenna. Thank you
