Got a magnetic mount vertical antenna at a Hamfest. Its base is about 4 or 5 inches in diameter and stands about 2" above the metal mounting surface. From there is a rod about 13" long going into what appears to be a plastic encased loading coil. This item is about 1/2" thick and about 3 1/2" long and has 2 black circular stripes going around the diameter of the coil. Coming out of the top of the coil is another thinner rod about 7" long topped with a round ball like a BB. There is about 17' of thin coax (RG58U?) with a PL259 coax connector on the end of the coax. Attached is a picture of the antenna in front of my dishwasher sitting on a oven broiler pan. Is this for 2 meters?
