KX4CD
A short piece of RG-8 coax stripped of its outer cover and shield braid can be used in place of HV cable.
I use an AH4 automatic tuner and a 102" whip and spring on my SUV with my 706, As mentioned it will operate from 40 to 6 meters. And yes I drilled the big hole and three small ones to install the ball mount. It is mounted on the left side just behind the fuel door. The tuner is mounted in the wheel well space and grounded to the main car frame.
BB
BB
Can u send pics of how you wired your AH 4 ICOM antenna tuner to go to your 102 inch whip. I am not sure how to do this as it has no connector to connect to a PL 259 connector - my rig is and ICOM 706 MKIIG
