I recently got an Alinco DR 638, and I would like to use 2 Larsen commercial antennas for it. I also want to use crossband repeat, so an antenna switch is not feasible.
I'm wondering if you can use a tee, like in the attached image, an split it to 2 separate antennas, tuned for 144 and 440. Will it function like a fan dipole, or is there something about vertical ground plane antennas that would make that not work.
I appreciate anyone's response.
Delta
Delta
