Go Back   The RadioReference.com Forums > Amateur Radio > Amateur Radio Antennas
Amateur Radio Antennas - For discussion of all amateur band designed antennas and related accoutrements. This includes base, handheld, mobile and repeater usage. For commercial antennas on the amateur bands please use Commercial Radio Antennas below.
Old 06-02-2017, 9:29 PM
KK4JUG's Avatar
Default Bugs and antennae
In the grand scheme of things, this subject doesn't rank very high but I'll put it out there anyway.
I recently returned from a 2,000 mile trip that was almost entirely on high-speed, limited-access roads. In course of that trip, I acquired a thick coating of bugs on my antenna. For aesthetic reasons, I've cleaned them off but does that the efficiency of the antenna?
Old 06-02-2017, 9:59 PM
I like these questions that want an answer to the question, but seem to think the answer doesn't need any details or just what your using.
My answer is the more bugs you collect, the more efficient it will be to collect more bugs. The faster you drive, the faster you will collect more bugs. Hope this answers your question.
Jim
Old 06-02-2017, 10:15 PM
Well as long as the antennae is a Texas bug catcher you should be good to go ! Congratulations and your accumulation , you level up again at 7000 miles.
Sent from my SM-T810 using Tapatalk
Old 06-02-2017, 10:41 PM
KK4JUG's Avatar
So, if my aim was to collect bugs, I shouldn't have cleaned them off? I'm assuming the bigger the antenna, the more surface area to accumulate the critters. Makes sense.
That begs the question: What's the cut-off point before destroying the antenna and should I get a higher wattage radio to burn them off?
Old 06-03-2017, 6:28 AM
W9BU's Avatar
Lead Wiki Manager
Depending on the surface coating of the antenna, leaving the bugs on the antenna can be detrimental. Bug juice can be corrosive.
Lead Wiki Manager and Forum Moderator.
"The whole world's living in a digital dream. It's not really there, it's all on the screen." -- WB6ACU
Old 06-03-2017, 2:09 PM
Bugs contain moisture, moisture absorbs radio waves, while the bugs are drying out I'm sure someplace like Sandia National Labs could actually measure the signal strength reduction caused by the bugs. Possibly a slight WSR increase as well.
This is why you are supposed to use antenna wax, so the bugs can't stick to the antenna.
Old 06-03-2017, 2:35 PM
ecps92's Avatar
All depends on what Flavors
Bill N1KUG
Cruise Ship Frequencies
http://www.scanmaritime.com
Old 06-03-2017, 3:11 PM
W9BU's Avatar
Lead Wiki Manager
Do you recommend the traditional Carnauba antenna wax or will the newer synthetic wax work just as well?
Oh, wait, maybe beeswax is the best choice.
Old 06-03-2017, 3:34 PM
DJ11DLN's Avatar
Only if it's impregnated with DEET. Keep them from splashing in the first place.
If it looks stupid but it works...it ain't stupid.
Old 06-03-2017, 8:52 PM
wtp wtp is online now
Default well
since some folks recommend insulated wire to transmit, in case someone comes in contact with it.
i would go with bugs don't matter much at all.
if they build up to the point where the car might be top heavy and flip over on turns, it is time to clean it off.
Old 06-03-2017, 9:31 PM
Use Beetle Juice!!!
Old 06-03-2017, 9:42 PM
KK4JUG's Avatar
It is an SUV so I'll have to be careful.
Old 06-04-2017, 7:39 AM
rfradioconsult's Avatar
Would this be called a buggy whip??
Old 06-04-2017, 8:01 AM
KK4JUG's Avatar
Groan!!
Old 06-04-2017, 11:20 AM
Would this be stored in a hangar next to the Propwash?
Bill
N4GIX - Ham / WQWU626 - GMRS
VV-898, TK-840(N), 2xTYT-7800, 2xUV5R v2+, HP1, BCD436HP, TMV7A, Ritron RRX-450 Repeater, MD-380, XPR7550, 2xCS800, Bridgecom BCR-40U Repeater, Elecraft KX3 + PX3
Old 06-04-2017, 2:38 PM
W9BU's Avatar
Lead Wiki Manager
No, but if you have any antenna wax left over, you may be able to use it to grease the muffler bearings.
Old 06-04-2017, 2:49 PM
KK4JUG's Avatar
I looked for those the other day. I couldn't find them. I guess they're sealed inside. If they go bad, I'll probably have to change the entire muffler.
Old 06-04-2017, 7:45 PM
Default if it is like my muffler
it says "no user serviceable parts inside".
Old 06-04-2017, 7:57 PM
Brts96's Avatar
You guys are still using mufflers that take mechanical bearings? Everything is all electronic these days.
The mufflers on my vehicles have muffler capacitors. They might need to be changed, soon, though.
I heard they eliminated muffler bearings years ago, but that's none of my beeswax.
Old 06-04-2017, 8:24 PM
KK4JUG's Avatar
Just my luck.
