Last time I did research on LMR400 type cables the attenuation was nearly identical for all brands and the internal dimensions must be the same to qualify as LMR400 type. There is a slight difference between the flex types and regular due to the stranded center conductor and different materials in the outer covering to make it more pliable.
Since the center conductor and outer braid must be the same dia in all cases the capacitance per foot should be about the same in all brands, otherwise it would not be 50 ohms. The difference you will find is the way the aluminum foil is attached, how thick and how much extra shielding the braid has and the outer covering characteristics.
Some brands will last longer outside than others due to UV. Some have stiffer had harder plastic coverings and others are more pliable. Some are designed for direct burial but most are not. Times is always a good default but I have some LMR400 made by Commscope that is really durable and looks like it will survive a nuclear hit.
I usually buy LMR400 off Ebay in 1,000ft spools when it gets down below $200. I also get lots of free LMR400, 500 and 600 left over from large satellite installations I work on.
prcguy
Is the attenuation the same?
Is the water absorption the same?
Is the flexibility the same?
Is the UV resistance of the jacket the same?
Will the jacket break down or bleed plasticizers the same?
Is the capacitance the same?
So many things to compare, but since the OP already bought it...unless he's going to scrap it, that doesn't matter right now, does it?
