Go Back   The RadioReference.com Forums > Amateur Radio > Amateur Radio Antennas
Amateur Radio Antennas - For discussion of all amateur band designed antennas and related accoutrements. This includes base, handheld, mobile and repeater usage. For commercial antennas on the amateur bands please use Commercial Radio Antennas below.
  #21 (permalink)
Old 02-11-2018, 7:08 AM
Default Another antenna question
Subtle is what I have to go with for antennas which is why I was thinking a 1/4 wave.
Unfortunately it appears that I canít locate a 1/4 wave that will hit both 444 and 469 so I might be stuck with the 1402.
Think of my ďmodificationĒ as having to ask for forgiveness rather than permission. I donít need a 30Ē antenna drawing attention to my modifications.
Iím new to the Ham side of the house having just picked up my technician after a fun little jaunt to Puerto Rico and St Croix where I encountered a lot of radio work-around in place.
Most of the time I work off a xts5000 but thatís being replaced soon with an apx8000 if the budget is approved.
  #22 (permalink)
Old 02-11-2018, 7:53 AM
Just get a “450-460” cut 1/4 wave and you’ll be just fine. It is not that critical, as long as there is a good groundplane under the antenna your VSWR will not be high enough to warrant an issue...
  #23 (permalink)
Old 02-11-2018, 10:16 AM
MCore25's Avatar
It's not a true 1/4 wave but will perform identically for all intents and purposes.
PCTEL MLPV430
It's roughly 4" tall but has a 2:1 VSWR bandwidth from 430 MHz to 480 MHz.
If a repeater IDs and no one is on frequency to hear it, does it even make a sound? Yes, because KC5MVZ is monitoring youÖ
  #24 (permalink)
Old 02-11-2018, 11:28 AM
mmckenna's Avatar
Good choice. A simple 1/4 wave whip will blend in very well on a full sized truck. The standard whips are nearly invisible unless someone is looking for them.
Unfortunately it appears that I can’t locate a 1/4 wave that will hit both 444 and 469 so I might be stuck with the 1402.
A basic 1/4 wave UHF will have very wide bandwidth. Back when I used to have a GMRS license, I used a 1/4 wave whip for both GMRS and 70cm amateur as well as some work stuff. Works just fine. The SWR is low across a very wide chunk of band.
  #25 (permalink)
Old 02-11-2018, 8:19 PM
My Comtelco 1/4 wave UHF with the spring is 100mhz wide at less that 2:1.
  #26 (permalink)
Old 02-12-2018, 8:39 AM
I ran by the shop and they had a uhf antenna thatís marked 450-465.
That should work for the uhf side right?
  #27 (permalink)
Old 02-12-2018, 9:13 AM
mmckenna's Avatar
Sure, if the frequencies you are using are in that general area. While it says 450-465, It'll cover quite a bit on either side just fine.
That's what we were saying about how wide banded 1/4 wave antennas are. That antenna is optimized for 450-465.
  #28 (permalink)
Old 02-12-2018, 9:19 AM
Gotcha. That's what I was thinking. SARnet in Florida is 444 rx/ 449 tx and I need to hit some stuff in the 469tx range too.
  #29 (permalink)
Old 02-12-2018, 11:23 AM
mmckenna's Avatar
You'll be fine with that.
I have a few antenna analyzer plots for VHF quarter wave antennas, unfortunately none of UHF.
I can tell you that on VHF, I have very low SWR from 140 up to about 170MHz.
The 1/4 wave antennas are great when you have a lot of spectrum to cover. And, considering the price of a new one, they should be a good first step antenna for most people. Jumping right away to higher gain/narrower bandwidth/more expensive antennas should be saved for a second choice. You can pick up a 1/4 wave UHF antenna for less than $10.00
