Just moved external antenna today for Kenwood. It is the same antenna, moved about 20 feet onto new pole. Worked fine before the move. When I go to attach antenna to back of radio, when center of coax connector is inserted into radio antenna connector, reception is 100% (listen to weather frequency), when I screw the outside of the coax connector onto the radio antenna connector, I loose reception. Are these symptoms of a particular problem. !! Thanks in advance. Joe
