poppafred
I have ordered a Tram 1411 discone for VHF/UHF use here at home but I have a question.
Has anyone ever found a set of instructions for the antenna?
The eBay photos shows it has 8 radials that angle down from the hub but two of them are longer than the rest. They also always show those two at an odd offset. You would think they would be 180 degrees apart but the photos never show that. Is there a particular reason to avoid 180 degrees?
Also, reports say that the antenna is not very good on 6m. Can you trim the whip for 6m resonance? It is supposedly good for 49 Mhz which means it is a bit long. Wouldn't shortening the whip bring it down into resonance on 52 Mhz?
In the long run, it will be fine for my local repeaters but would be nice to find a way to expand its capabilities.
