I've used aluminum tape to make ground planes under antennas.
Issue I ran into was under a plastic roof on an ATV. While not a PVC pipe, it was similar material. Contraction/expansion from temperature changes and flexing eventually damaged the tape. It would basically wrinkle when the plastic contracted, and when it expanded, the tape would tear.
So, interesting idea, and if you could find some way of making sure the tape didn't get damaged, it might work.
But I think you might be better off using a thicker material, or just using the pipe to support a wire internally.
