Murphy625, may I ask why this is a temporary installation? What are you trying to measure?
I'm trying to create a portable antenna that is easy to deploy and can "reach out and touch someone" without the need for repeaters. A true stand-alone system that can go wherever I can. The area I live in is very hilly.. no mountains or anything, but we do have elevation changes that can vary 40 or 50 feet.. it creates problems for the higher frequencies as I've learned with all the antenna software I've been screwing with. I learned a lot playing with the antenna software stuff lately.
As for the RG-8/U, are you aware that there is
RG-8X (miniature RG-8) that is about half the size of RG-8/U but has similar characteristics? Even though RG-8X has more loss, the weight trade-off and flexibility of RG-8X may make it better to use. If you are just going to make some receive signal measurements, you have the specs on both types of cable for comparison purposes.
Eventually, I will be transmitting.. I'm just not there yet.. but I'm close! I took a practice "General" test this week on one of those websites.. I didn't pass, but I did notice that my wrong answers were mostly on arbitrary questions and not the ones based on physics. For instance, when they asked about SWR, impedance or grounding, I got those questions correct, but when asked about the rules and regulations, I missed on those questions. At least I know where to focus my study now.
I pass the practice tests for technician every time but plan on taking both tests when I go.
The RG8X has almost almost twice the loss as compared to RG8/U, and at a 50 foot run up a tree, I think it becomes somewhat significant from the limited knowledge I have about this stuff. Its not so bad at lower frequencies, but at 144 and 440, it gets bad really fast. In fact, it gets stupid at 440.
Because of the terrain, I have to be able to punch through the tops of trees and not have my signal evaporate on the other side.
Which brings me to another question.. Would VHF go further in the winter due to the lack of foliage or would the higher air density counteract that benefit?
The slingshot/fishing reel method of getting a line up into the tree is great. That is what we use around here although one guy does have a spud/tennis ball compressed air gun which is more accurate that we sometimes use. Here is one of many websites about antenna launchers.
Pneumatic Antenna Launchers Let me know if you set out to build one...
73, Dave K4EET
Ya, I didn't come up with it on my own.. thanks goes to youtube for that. I considered the air cannon but its less portable than a slingshot. I put a 20lb line with a 1oz lead weight over a 100 foot maple tree with room to spare... any more power and I'll have to file a flight plan! Its scary how well that works using such old school tech.
