I have used 1/2 inch copper pipe with a CPVC tee as the center insulator. I just use two machine screws to make a connection to the pipes from coax. I have found I get a bit more bandwidth with the pipe. If you use another chunk of PVC as a 'mast' a dipole made from pipe is rotatable. I turn mine by hand and then tighten the clamps back down. Changing the direction allows you to point the antenna every once in a while which may get you a few more grid squares -or point at the magnetic pole for aurora.
