For the past few weeks I've been listening to 20m during the day with a low-mounted dipole. That is, it is only up about 14 feet.
For really low angles, I'd need to mount it higher. But propagation during this part of the cycle doesn't really support that. My vertical is pretty sad too. Nothing much there at low angles, except for some rare openings.
More or less that means short-skip, up to about 1000 miles or so.
I guess it is no surprise that the best signals are ALSO heard from stations using antennas that are not dx-chasingly high up, but down lower, and running power, where the higher angle refraction is far more efficient than weak low angle absorption.
I'm just wondering how many amateurs with height adjustable towers and so forth have cranked them down lower to better support the high-angle skip and not end up in a "no man's land" of poor low-angle refraction no matter how much power you put out....
At this poor part of the cycle, it seems fun during the day - made even more fun if the OTHER guy is also putting out a nice higher angle too. My thought is that if you aren't really working DX anyway, put out a better high-angle signal by dropping the antenna.
It seems so counter-intuitive to go low(ish) but has been working for me. It still takes a bit of work at times, but at least I'm not just refracting into nowhere or getting totally absorbed with low angles.
