Lots of options here...
The most basic would be an Opentracker + loaded with KISS firmware and then UI-View on a computer to monitor what it receives.
I now run an Opentracker 2, OT2M, and a Garmin Nuvi 350. Everything you need in one small package. Displays stations received, transmits your location, and even has APRS messaging.
You could also get a cheap used TNC, Kantronics, MFJ, you name it, and again run it in KISS mode with UI-View. All depends on how you want to use it, mobile, stationary, etc.
The added benefit of using a Opentracker or TNC and UI-View at home is you can also become a Digi or Igate if your area needs it. Make sure if you go that route you get the PA7RHM map server for UI-View, gives you full mapping capability with UI-View as it downloads Navteq maps.
