APRS on a drone?
Jay911
Silent Key (April 15th, 2023)
Bragg Creek, Alberta
Hey folks,
Anyone ever explored the possibility of outfitting a UAV with a tracker?
I have a DJI Phantom 2 Vision+, and I'm suspecting that even a cheap HT with a TinyTrak and GPS would be over the payload capacity by huge multiples. Something that could take the GPS signal off the device itself and maybe a small battery of its own (so it's not reducing flight time by taking from the aircraft's battery) might work, but I'm not aware of anyone who's made such a kit.
What's used in APRS balloon launches? Is their payload large enough to handle an HT, or do they have smaller kits for this purpose?
Not planning on duct-taping my VX-8GR to the drone just yet... ;)
DanRollman
Atlanta, GA
Hey folks,
I have not yet tried hoisting a HT with my Phantom 2 (though the idea has certainly crossed my mind), but there are plenty of YouTube videos of people lifting heavy DSLR cameras and other objects with a Phantom 2. It generally works ok, at best. Flight time gets really, really short because the motors are applying so much more power to stay aloft with extra weight.
AK9R
Super Moderator
Central Indiana
Argent Data also the T3-Mini which weighs 5.5 grams not including battery or GPS receiver.
A lot of the balloon launch guys use the BigRedBee device which is also made to be small and light.
prcguy
This is what you want for lightweight APRS on drones, baloons, etc, :AP510 Aprs Tracker VHF with GPS Bluetooth Thermometer TF Card Aprsdroid US SHIP | eBay
Its completely self contained with a 1w VHF transmitter, GPS, modem, battery that will last more than a day and I use one all the time in my vehicle but they are popular for aircraft and balloon launches.
But I would ask why you would want an APRS specific thing on a DJI Phantom that is usually flown within a couple of blocks of the pilot? You can get tiny boards that add GPS positioning of the drone onto your ground video monitor using the GPS built into the drone. These will remember the last known location in case you crash beyond line of sight and the parts cost less than an APRS tracker.
prcguy
ki6vbk
I actually have a project designed for exactly this, take a look at tracksoar.com and I've posted the full source code and schematic for an APRS tracker small enough to fit on most drones.
KF0X
Tucson
Hey folks,
My concern is the tracker (although on a dramatically different frequency that the drone) could possibly overload the front end of the drone radio and make it uncontrollable or even crash. Normally with Amateur Radio I would experiment, but I am scared to do that with a drone up in the air costing $1000+.
Thoughts???
pinballwiz86
Missouri
Thoughts???
1 watt of RF on a completely different frequency won't do anything to overload the drone's front end. If you're still worried, just do a ground test.
KF0X
Tucson
Actually the tracker I wanted to use can be turned down to 300mw. I have a DJI Phantom drone. I know the transceiver on those things has to be really cheap (although it works incredibly well). I can most certainly ground test it, but nothing is a replacement for air testing, particularly when I can have it out there 2000 feet at 400 feet high. The only way to attach APRS would make the antenna of the drone and the APRS less than 4 inches apart. I have seen strange things happen before with interference that technically-speaking should not happen. It would be so cool to have APRS on it. I wish I could get people that were braver than me that have already done it with the same drone and a <1 watt APRS transmitter.
