All I see is JT65 and JT9. Set your computer clock within 2 seconds of a standard time and you should be able to decode it correctly with WSJTx
WSJT Home Page
WSJT Home Page
So I got that up and running I think. I have the sdruno using its output as vbcable. wsjt's input as vbcable and speakers out. The water fall is doing something but no sound. Is that normal? I set it to whisper and set the sdruno to the low frequency LW band. How do I know if its working? Do you have to mess with the sdruno every time you want to change frequencies?
