Go Back   The RadioReference.com Forums > Amateur Radio > Amateur Radio Data Transmissions
Amateur Radio Data Transmissions - For discussion of all modes used to send data such as APRS and packet.
Old 11-16-2017, 12:42 PM
Default LoTW for Linux question
Hello everyone. im trying too get my certificate recognized in Lotw. i run Lubuntu 17.10 tqsl v2.3 i got the certificate via email but it will not be accepted by lotw.
anyone had success with this??
Old 11-16-2017, 2:08 PM
popnokick's Avatar
Did you compile and build a linux version of TQSL? You need to load the cert into the TQSL app. If so, is that where you are having a problem (loading cert into TQSL)?
Old 11-17-2017, 6:42 AM
Hello there
Thank you i installed TQSL thru a repository via synaptic, Now i did do the update and install the cert, then it took my certificate and is working well,
Thank you again i appreciate the help 73 KC3JET
