I want to connect my Yaesu FTM-400XDR radio to a Kantronics KPC-3+ TNC. I THINK this is what I need. First a Yaesu CT-164 cable to convert the radio's 9 pin data port to 6 pin mini DIN. Then an MFJ-5060YV cable to convert to DB-9. I wanted to make sure the pin functions matched but I'm confused by the terminology. E.g., pin 4 on the radio says, "RX 9600 (9600 bps packet data output)". RX is receive but output implies TX. So is the radio receiving or transmitting on that pin? Using these 2 cables, it connects to pin 5 on the TNC which says, "receive audio". My question is, is this the correct connection? I.e., do these 2 terms mean the same thing? I think this is TX from the radio & RX on the TNC side, but not sure.
I'll attempt to attach a spreadsheet with data on all the pins.
P.S., on the Kantronics website for the pinout, it says "AKSK in". Is that a typo & it should really be "AFSK in"? https://www.kantronics.com/documents/kpc3ppinout.pdf
