Anyone using the VX-8R? I've read the eHam reviews, but I'm looking for other input.
Great little radio, only thing I don't like is how the battery fits loose on the back of the radio. Too much "play". I see the same thing happening to the 8R as the FT10/40 FT50, when the battery contacts get a bit worn or dirty, the radio crackles and/or breaks up on high power transmit. Battery capacity is a bit low too for my taste
Wish they made it out of metal like the 7R / 5R.
Becasue of the above issues, I will not be buying a VX8R.
Because of the above issues, I will not be buying a VX8R.
Thanks for the report. How does it sound to others on repeaters and simplex? Is the power output adequate? How about the ham reception vs. general coverage?
I see one positive report on this so far.
...How about the ham reception vs. general coverage?...
Just used it today over lunch. Repeater reports were just fine. I used a Diamond RH-77CA while in the car, as well as the stock antenna when I was standing outside.Thanks for the report. How does it sound to others on repeaters and simplex? Is the power output adequate? How about the ham reception vs. general coverage?
