RadioDaze
Regarding assigning memory channels to banks... I accidentally assigned a channel to two different banks.
How do I "un-assign" one of the instances? (I want it in bank 1 only, not also in bank 2.)
Can it be done from the keypad, or do I have to edit it in the PC software and re-clone it?
I know how to assign the channel to a bank, per the instruction manual page 33:
1. Recall the memory channel to be assigned to a Memory Bank.
2. Press and hold in the [BAND(BAND DN)] key for one second,
then rotate the DIAL knob to select the Memory Bank number
you want as the Memory Bank for this channel (“BANK 1” ~ “BANK10”).
3. Press and hold in the [F/W] key for one second to copy the memory
channel data into the Memory Bank.
That's all I could find in the manual. I tried to assign it again to the wrong bank, to see if it "toggles" it off, but no luck. No luck selecting "no bank" as the target either.
