enduser56
Hello.. looking for help and advice. Here's what I can do. I can remote control my FT857D with Ham Radio Deluxe for the control, Logemin.com for the PC to PC connection and Skype for the audio. It works great if all I want to do is monitor. However, I want to go the next step and transmit remotely with a standard PC headset on my laptop and that's where I'm totally lost.
To continue, I bought a serial/usb sound card interface some months ago from a ham radio store that has the two 1/8" jacks on the end (one is labeled "mic input", the other is "speaker out"). It's supposed to let me run PSK31 but it appears I might also use it thru the 857D and HRD to transmit phone as the label on the interface states "sound card interface for PC generated PSK31 and RTTY modes. PTT support on serial port RTS line". It would seem then that I could set this interface to make the 857D route around the radio's mic and instead see audio from my sound card as the transmit audio.. or, am I way off base with that thinking?
HRD does give me a live TX button but when I activate it nothing seems to be going out the radio and tuner. I've plugged the "mic" and "speaker" end of the plugs into my host PC with every arrangement I can think of with no luck. I know there are settings within HRD and on the 857D too that I'm probably not observing.
Anyway, if someone can lead me thru or suggest a helpful tip, much appreciated. By the way, I am able to use the interface successfully to receive PSK31 but again, I can't get the PSK31 transmit going.
Dale - KC0NZM
Dale - KC0NZM
