KD8MZM
I just got my Tech license and have been looking for my 1st rig. I've been trying to find a used solid-state HF transceiver for $250 including everything (ie. mic, manual, power supply, shipping, etc.). But that's proving to be impossible.
So I started looking at older rigs. Being new, I discussed them with the ham who helped me get my license. He checked around with other hams and gave me a list of reasons why he wouldn't buy an analog (tube final) rig. But I'm not sure I agree and don't mind learning about older technologies. However I would like to find out if these concerns are valid.
1) don't buy an older general receiver. it would mean you can only listen to ham bands.
2) all older rigs have mechanical problems - failing/broken switches, noisy pots, and unreliable solder joints.
3) avoid rigs with tube finals - here's why;
a. very tricky for a new ham to learn how to tune tubes which you must do EVERY time you change frequencies. Takes to 10 minutes each time. (solid-states are automatic)
b. tube finals always go bad (power reduces over time and it will cost you over $100 to replace a matched pair IF you can find them)
c. the driver tube will need to be replaced
4. analog meters are unreliable and must be calibrated (make sure your rig has all digital meters)
5. older rigs cannot be connected to or controlled by computer
The more I think about this list the more I'm wondering if some of these concerns are because he can afford and only runs newer, solid-state equipment.
So if I can get some comments/opinions, I'll be able to decide what to do.
Here they are:
1) if i buy a general rig, what would i be missing?
2) do older rigs have more mechanical problems than newer rigs?
3) how hard is it to tune tube finals when making contacts (ie. what exactly do you do and how long does it take)
4) should I worry about modifications?
5) if output power is lower than specs is this a big problem (ie. new tubes? - how hard are they to find)
6) is service (ie. meter calibration) easy to find if i chicken out on doing it myself?
I'm fairly handy with a soldering iron and don't mind working on my own equipment IF I think it's worth it.
Sorry for the length of this note but I really would like to know the answers and am hoping to find something soon that I can afford.
Thanks for responding.
Larry
KD8MZM
Here they are:
Larry
KD8MZM
