Mtune means you are changing the frequency or mode while in Memory mode. To switch from mtune mode you can turn the the channel/memory select knob or copy the frequency to VFO A or B.
If you are on memory channel 1 that is set for 14,313 MHz and turn the dial the radio automatically switches to mtune mode so you don't have to copy and switch to VFO A or B.
