KE5PGE
I have an AT 250 that I use with a TS-430s that is giving me grief in a way that I have never encountered. After I have made all of my connections from the radio to the tuner, I cannot receive. When I was disconnecting the coax from the back of the radio I was able to get great reception as long as the outer barrel portion of the coax connection wasn't making contact with the receiver. In other words, when the pin part of the coax only is making contact, I can get Rx with no problem. I disconnected my antenna coax from the back of the tuner and connected straight to the radio and there was no problem. The condition exists only when the connection is made going through the tuner. I thought that maybe it was an defective diode that is causing a back feed but even that I'm not sure where to start looking. It is obviously a grounding problem. I sure would appreciate any help that I can get in finding a workable solution.
Thanks for your help
