Amateur Radio Equipment - For general and technical discussion of Amateur Radio equipment such as transceivers, repeaters, controllers and receivers.
Old 05-11-2013, 6:27 PM
Kingmobileaudio's Avatar
Default External Speakers ohm
I pick up two speakers from a local Kenwood dealer "kenwood kes-3 4ohm" for my TM-v71.
I just started looking in the manual and came across External Speakers pag.7
It says
"If you plan to use external speakers, choose speakers with an impedance of 8 ohm.
They recommend using Kenwood SP-50b
Will these speakers damage my radio? Or will they work fine?
Sent from my iPhone 5 using Tapatalk 2
Old 05-11-2013, 9:02 PM
KF5EYR's Avatar
They will work. But, the 4 ohm speakers will allow more current to flow from your radio. More current means more heat. If you think your radio will dissipate the heat, and not overheat; you should be fine. As long as you listen at a moderate volume, I don't think it will be a problem. I have 2 Polk speakers hooked to an Icom 2200H. Never had a problem. I don't really that you will.
Icom IC-208H, Icom IC 2200H (w/D*Star)
Yaesu VX-6R,
RS PRO-163, RS PRO-18, Tecsun-880
Old 05-11-2013, 9:04 PM
Thank you! Better safe then sorry!
Old 05-11-2013, 9:21 PM
KF5EYR's Avatar
You're quite welcome. I might add that the Polk's I have hooked to my Icom, go a long way to prevent "listener's fatigue". The sound is nothing short of stellar.
Yaesu VX-6R,
Old 02-02-2018, 12:29 PM
Sorry to resurrect a five-year-old thread, but I found this post because I want to drive a single Kenwood KES-5 external speaker with a Kenwood TM-V71A, and I'm also concerned about the impedance mismatch between the 8Ω transceiver and the 4Ω speaker.
I'm curious if the original poster proceeded with using the speakers with the transceiver, and if there were ever any issues.
Old 02-02-2018, 12:34 PM
Didn’t really have an issue with it working.
I did not like that they where not loud enough for my install. But that’s due to how small they are
Sent from my iPhone using Tapatalk Pro
Old 02-02-2018, 1:31 PM
Just for the record, I emailed Kenwood, and almost immediately received a reply back from someone in their amateur radio technical support group. He wrote, "The Kenwood KES-5 speaker will work fine with the TM-V71A. No need to look for anything else."
I thought I'd share that in case anyone else stumbles onto this thread with the same question.
73, N5MAJ
Old 02-02-2018, 4:32 PM
Default Kenwood KES 5 speaker
I have tried a lot of speakers on my Icom 7300 and the Kenwood KES 5 is the best.
Old 02-02-2018, 4:43 PM
cmdrwill's Avatar
Right from the Kenwood service manual spec sheet:
Low frequency output (8Ω) More than 2W (at 5% distortion).
A lower impedance speaker like 4 ohms will work with the audio amplifier in the TM V71/ 710 radios with some loss at lower audio frequencies due to the coupling capacitor in the audio amp output, 330uF. The audio IC is IC801 a LA4629 and spec'ed at:
PO(2) VCC = 12 V, RL = 4 ohm THD = 10 % 4.0 W
Old 02-03-2018, 4:58 PM
Also, the lower impedance speaker will be louder than the higher one. For years, Motorola sold radios with 8 ohm speakers. But for only $79 extra, you could get a "higher output " speaker for use in noisy environments. It was the exact same speaker, but it was 3 ohms instead of 8. A quick $79 profit for something that cost them nothing extra. And yes, it was substantially louder.
FORMERLY MOONBOOTS
Old 02-03-2018, 5:53 PM
MCore25's Avatar
They still do that...7.5W speaker comes standard with most APX radios and the 15W version can be ordered as an option.
If a repeater IDs and no one is on frequency to hear it, does it even make a sound? Yes, because KC5MVZ is monitoring you…
Old 02-04-2018, 12:40 AM
but the cool thing is the audio amp in the Moto may very well put out over 10 watts
unlike the wimpy ham rigs that distort at 1 watt
