Kenwood: Kenwood TM-V7 Reset
3me
Shawnee, KS (Kansas City metro)
Unfortunately, my Kenwood TM-V7 seems to have lost its mind. Some of the programming does not work following the manual and other features disappear each time the power button is turned off. I am afraid it is time for a HARD RESET and to nuke the memory. The only reset I could find listed in the manual was to erase the memory channels, but that did not resolve the issues. I would like to reset it completely back to factory condition and start anew. Does anyone know what combination of buttons will accomplish this?
de WAØKS
Shawnee, KS
AK9R
Super Moderator
Central Indiana
The manual mentions a button hidden by the display that will do a full reset. See the Maintenance section of the manual.
cmdrwill
So Cali
If it is an older ' V7 ' it may have a button size memory battery. Those go dead over the years. It may be soldered i no one of the boards. May be on the control head circuit board.
AI7PM
The Intermountain West
Remove the face, and on the panel, slightly to the leftt, you will find a small hole that contains the switch. Use a non-sharp tool of appropriate size to press that butoon in, AND hold for more than 1 second. That is the "Hardware re-set" procedure.
