Hello,
I have a Technician license and a portable handheld radio (YAESU VX-5R) which has been great, but I would really like to set up a base station in my home.
Since I am currently unable to set up an antenna outside, I was thinking about getting a mobile unit with a magnetic antenna so I can use it inside my home.
What would be the best Mobile/Portable station, power supply and antenna I can set up inside my home? I am leaning towards the Yaesu brand since that is what I am used to and my Yaesu handheld radio has held up really well (14 years!)
My handheld is a Tri-Band (144/2m, 50/6m, 430/70cm), but all I am seeing are dual band (144/2m, 430/70cm) or quad band mobiles. I would like to be able to have VHF/UHF capabilities as well as listen to local police, fire, aviation, weather, etc, (Wideband?). I won't be doing any CW. I see that a lot of radios are analog and digital now?
I am considering the Yaesu Original FTM-100DR 144/430 C4FM Digital / FM Analog Dual Band Transceiver and the MFJ-1728B Magmount antenna, 6m/2m, 4ft, 12ft coax. Not sure about power supply?
Or would I be better off getting the Yaesu Original FTM-400XDR 144/430MHz Dual-Band Analog/Digital Mobile Transceiver System Fusion?
Or save up for a portable station like the Yausu FT-991A HF/50/140/430MHz All-Mode Field Gear Radio?
There is so much out there. I apologize, as I have been "out of the loop" for several years. I am a crazy busy mom of three little boys. Now that they are in school, I would really like to get back into "ragchewing" and listening in to what's going on locally.
I would love set up an antenna outdoors, however, I don't think the association in my town (Winfield, IL) will let me...
Thank you for you advice in advance! It is much appreciated!!
73'
73'
