Amateur Radio Equipment - For general and technical discussion of Amateur Radio equipment such as transceivers, repeaters, controllers and receivers.
  #21 (permalink)
Old 01-30-2018, 6:57 PM
jonwienke's Avatar
Originally Posted by KD2LQG View Post
I recently built an emergency kit and if I had to choose between the hard plastic case I have now and an ammo can I would definitely choose the plastic case. And unless you are planning on using a dual band radio there is no way you can fit 2 radio's in an ammo can.
The 20mm, 40mm, and 30mm ammo cans are much larger (4-6x more internal volume) than the .50 cans, and have plenty of room for multiple radios, a battery, and misc storage for mics and such.
https://www.amazon.com/dp/B001888MYY/
https://www.amazon.com/PA-120-40mm-A...dp/B006A7L2C2/
https://www.amazon.com/Can-Military-...dp/B01LFIFPAK/
  #22 (permalink)
Old 01-30-2018, 7:01 PM
Oh ok I have a .50 can and it isn't all that big.
Motorola XPR6550, HT1250, CDM1550LS+, XTS5000, CP200, CP150, CP200d, XPR7550e, 2 MCS2000, 2 I355
TYT MD380
Kenwood TK880
