I recently picked up a Tera TR-590 HT and have been playing with it side-by-side with my Yaesu VX-7R. One thing I'm noticing is that the RX on the NOAA weather (WX) frequencies is MUCH better on the TERA. The Tera has the factory rubber duck antenna, and I have the factory rubber duck and a telescoping Smiley antenna for the Yaesu. It doesn't matter which antenna I have on the Yaesu - the Tera is pulling in a perfectly acceptable signal while the Yaesu sits silent. If I press the "monitor" button on the Yaesu, I can hear a bit of something, but it is pretty bad.
From what I know, the Yaesu has the weather frequencies built into the firmware of the radio and there is nothing that I see that I can tweak in the VX-7 Commander software; I haven't tried CHIRP yet. I have tried adjusting the RX Mode via the keypad for the weather channels (from NFM to WFM) and that helps, but as soon as I change to a different frequency, the radio changes my edit back to NFM.
So I'm trying to understand why a "CCR" is outperforming my $300+ HT on the WX receive, especially a radio that has a dedicated WX memory bank like the VX-7R. Frequencies of 161.xxx to 163.xxx lay right in the middle of the HAM bands, and I have a better antenna for the Yaesu, so this is not what I would expect. I'm guessing I may have changed a setting somewhere but I'm not sure what, and was hoping to get some ideas from the community here.
Thanks!
Thanks!
