I would be transmitting on 27MHz, but when I get my technicians license I'd like to be able to transmit on the allowed bands for said license also. Or at least some of them. Seems like it would be pretty tricky to do CW while driving. If you can even put up big enough antennas for those lower bands while mobile.
You are better off with separate antennas. The diplexers/triplexers, etc. are not fine enough to just slice out the amateur spectrum and leave the rest for your scanner. The amateur grade diplexers are pretty broad, so you'd end up with a scanner that was pretty deaf anywhere near amateur bands.
Install a dedicated scanner antenna for your scanner(s).
Install dedicated antennas for your transceivers.
How do I go about tuning the filters?
To do it right? Expensive test equipment.
Also how can I protect the scanner front ends from the transmitting antennas?
Separate antennas with as much space between the scanner antenna and the transmitting antennas as you can get.
Yeah, installing some extra antennas for the scanners is an option. I want to install this setup on my semi-truck though, just not sure where I would install the scanner antenna/s. Maybe on the front of the hood, but that would might reduce what they could pick up with a big trailer behind me. Higher would be better but not sure where I could install them.
It's really the better way to do it. Dedicated antennas will work better than trying to force a bunch of equipment to share one.
Where you end up mounting your antennas will depend on a number of factors. To make any sort of sensible suggestion would require knowing what frequencies, what power levels, how many antennas, what else is on the roof, what your skill level is, what your budget is, how comfortable you are drilling holes, etc…..
Or I could use a diplexer and a scanning cb radio or ham radio when I get my license, I like the radios that scan better because it's the best of both worlds and I don't miss transmissions on other channels that way.
Uniden does make a CB with a built in scanner, but it's sort of a limited scanner. You'd still need two separate antennas, though, one for CB, one for the scanner, and don't forget about the GPS receiver in it.
Any recommendations on antennas for this type of setup?
Depends entirely on what radios you are running, what frequencies you want to use, etc.
Larsen NMO-150-450-800 is a good choice for an all around scanner antenna, but it doesn't perform on VHF low band, which you might want.
For CB, it's hard to beat a half wave/no-ground-plane antenna(s) on the mirrors.
For your amateur radio stuff, it entirely depends on what bands you want to use.
