Un-boxed a new AT-6666 this morning. Was pretty excited, until the initial power up started. Unhooked my 2m/70 band radio from the truck, it came with a "T" style-quick connector so I installed male leads on the ends of the AT6666. Hooked the male leads into the quick connector and immediately blew the 15amp fuse on the power line.
The quick connector goes straight to the battery and ground in the engine bay. I tried again, blew another fuse. I reversed the wires, and blew the 15amp ground fuse on the lines coming from the engine bay.
I then wired it into a power port on my truck used to run a trans temp gauge. This time it blew the 10 amp fuse in the truck's circuit.
Finally, hooked it into a cigarette lighter adapter I had. This was plugged into a 120v-12v home converter but once again, it blew the 15amp fuse on the radio power line again.
To me it appears as if the radio is a lemon, perhaps wired incorrectly internally? Any advise guys? I've run 3 vhf/uhf rigs across 2 vehicles and a house for 2 years now and never had this issue. Stumped to say the least.Thanks
