...snip...
Looks like if you look at the values after a memory channel is stored, & then you change the value, the new value will be stored into the memory channel without pressing the MW key. Is that right?
...snip...
This makes it really easy to change Tone/Tone Sql.. Recently worked at a public service event and wanted to change my cross band repeat tone. Since I already had Tone/Tone Sql for the frequency I was using, all I had to do was go into SIGNALLING and change tone. Even when you do not have a Tone or Tone Sql for a frequency, one just has to turn them on. That is, no fiddling with going to VFO and turning all parameters on, then having to MW all this info. Just putting tone on will keep that on the memory frequency. This makes it real easy to change tones if travelling to another area where Tone is different. One just has to remember to change the Tone frequency back to your local area. Or if added Tone/Tone Sql to a frequency, it will remain unless you remove the Tone/Tone Sql. function.I'll amend what I said earlier after sitting at my 400D and playing with tone menu.
Select a channel and go to the setup signaling tone squelch frequency and what you see in green is the programmed tone. Switch it to orange and change to a different tone and switch back to green. That becomes the new tone frequency and is stored in the currently selected channel without using MW. Typically for other radios I've used, menu changes temporally effect a selected channel, but switch to another channel and back restores what was originally save.
That was a bit of a surprise and not expected. I know for sure the channel I selected that's how it works. Tone was 110.9 and I could bring up the repeater. Changed to 100 and could not, changed back to 110.9 and could. I could go one step further and after a change at the radio, read it back into my programming software (RTS) and see what changes were made. I'm not really that curious to cross check, but it something that might help you to get a feel for how front panel changes effect the stored information.
Not unusual for the manual to be obtuse about interactions between menu or so well hidden you can consider it not there.
Programming software will make life easier!
So, to repeat slightly, I'd like to know all the info that's stored into a channel. Is there a complete list somewhere? Here's the list I've created. Did I miss anything?
DISP/SETUP hold
MEMORY; 1 ALPHA TAG SIZE
SIGNALING; 1 TONE SQL FREQ (set tone freq)
CONFIG; 4 AUTO RPT SHIFT; on/off
CONFIG; 5 RPT SHIFT
CONFIG; 6 RPT SHIFT FREQ
F/MW
SQL nnn (e.g., T-TX to transmit tone)
Tx PWR
