Goal is to consolidate multiple repeaters spread across the area and have a central location that can receive all the repeaters and transmit out onto one main channel. all of the other repeaters are receiving the same handheld frequency and then repeating out onto a separate frequency. Id like to take all of those repeated frequencies and turn it into one channel.
If I read this correctly, you have a number of repeaters that receive portable traffic on one channel, let's call that F1, and each repeater transmits on F2, F3, F4, F5 etc.? Is this correct?
That is a multicast system. Usually a multicast system has a signal to noise voter ,like a JPS SNV-12 to select one transmission on F1 and retransmit on F2 through F5 etc.
However, you can have totally separate repeaters each receiving F1 and transmitting independently on F2 through F5 etc. It will work, but the likelihood of it working well is diminished.
If what you want is for all repeaters to receive F1 and transmit F2, it can be done and it is called Simulcast. You need the signal to noise voter and you also need hardware to synchronize the audio to all the transmitters . HARRIS synchrocast is one solution. You also need to have all the transmitters the exact same model and vintage, a GPS derived frequency and time reference. A CTCSS tone generator that is synched.
If this is what you seek, look up the webpage for Simulcast Solutions . Talk to Ed O' Conner there and he can help you work up a budget. His site has a wealth of information on doing this right.
You may have to be concerned with the limitations of simulcast when covering a huge county. This is where coverage modeling becomes important. You will need someone skilled in the art of simulcast computer modeling to determine which sites are useful for Simulcast.
Another alternative is DMR with IP site connect which can multicast transparently with automatic roaming. You will have to replace subscribers to enjoy that capability.
Drop me a PM with your phone number if you need to delve into these options further.
