Hello all,
I'd like to just lay out my current repeater setup and would like some help with diagnosing a problem that I'm having with rx reception, for some reason there will be this intermittent problem of static and signal degradation to the point where the signal will drop for a second or two and then come back. Humidity does seem to play a part in this but here is the full setup and maybe someone can let me know what the issue is.
Repeater - Vxr-7000v
50' lmr 400 n type cable connected to lighting arrestor which is then grounded to a groundrod
rooftop mounted Commander technologies 220-3AN
TPL 250w amplifier
Duplexer from a local company (specs)
Frequency separation, MHz 0,6-15
Bandwidth, MHz 0,5-2,0
Max. input power (continuous-duty), Wt 250
Insertion loss RX-ANT, dB < 1,5
Insertion loss ANT-RX, dB < 1,5
RX isolation ANT-RX, dB > 90
TX noise suppression TX-ANT, dB > 90
Impedance, Ohms 50
VSWR < 1:1,2
TPL 250w amplifier
Impedance, Ohms 50
VSWR < 1:1,2
