I got the Yaesu FT-51R working, had to fashion a new battery pack for it but it works quite well.. a bit on the complicated side menu wise but I'm getting the hang of it.
Along with the box that the FT-51R came in, I found another radio in there.. This thing is the size of a credit card and is called an Alinco DJ-C4T (440Mhz version). It was literally sitting under the bottom flap in the box hiding under all the cables and garbage.
Seems as though this one is also older than the internet and I can't find any useful documents on it. The lithium battery is completely toast so I hot wired an 18650 battery to the PCB power terminals.. It should run for a week on that battery.
The problem is that I think there might be a busted connector inside the speaker jack and I can't seem to get it out. The radio has no actual speaker and requires earphones if you want to hear anything. I think maybe the tip of the 2.5mm plug might have broken off inside the jack housing.
I need to disassemble the radio's pcb boards but it would seem that I'm not intelligent enough to find all the screws because I can't get to the speaker jack.
Once again, I searched to the end of the internet and can't find a service manual.. Anyone know where I can find one?
